Discussion Starter #1
This is a decent straight axle. No spindles.Kingpin holes are not worn out. Spring perches have been cut of so there is still a small piece in both holes. Did have some shocker brackets welded on ,these have been removed and cleaned up with the grinder so you won,t have to bother the neighbours with that task. Axle does have surface pitting, needs a blast and a thin coat of filler to look 100% again. Genuine heavy axle , not the thinner model. 220 Quid only at the NSRA swapmeet this Sunday the 7th. posted four pics to give a good view of the axle. See 'ya. Henry
32 heavy axle
Hi, have you stiil got '32 axle for sale?
Cheers Nick
