Hi, For Sale.. 1950 F1 Pickup.
Lowered 18", E300 Mercedes Diesel and Fully pro built 4 Matic Trans on the column.
This has just been finished and has only done 60 mile up to now.. but this will go up as I'm using it.
This has been built to use as and when and drives great....
All new to the truck....
Engine has had a full service with all filters, belts and runs great.
Engine Mounts(New)
Trans has had a full rebuild with new converter and bands.
Trans Mount (New)
Alum rad with built in trans cooler (NEW)
Rad hoses (New)
2800 rpm Elec Fan (New)
80 amp Alt (New)
Fuel Lines (New)
Battery (New)
Full wiring Harness (New)
Horn (New)
All Switches (New)
Omega Quad Gauges (New)
Elec Wiper kit (New)
Stainless Wiper Arms and Blades (New)
Rebuilt Heater with new rear stat
Head lights (New)
Bezels S/S (New)
39 Fog Lamps (New) and hard to get.
Full Stock interior (New)
Full Glass set (New)
All rubbers, Glass and door (New)
Deluxe Window run set (New)
46 Ford Deluxe Steering Wheel (Original )
All Dash Trim (New)
Interior Door Handles (New)
Sony mp3 player with 6 x 9 speakers (New)
Front Suspension is Original axle at has been dropped and pulled
Posse dropped Springs (New)
U-Bolts (New)
All Shackle Pins (New)
King pins (New)
Tie Rod Ends (New)
Steering damper (New)
11" Disc Brake Kit and Dual Power Booster and M/C (New)
All Brake Lines with Res and Prop Valves(New)
Rebuilt F1 Steering Box with New Pitman Arm
Rebuilt Drag Link (New Parts)
Pro custom slide one p/c Prop (New)
Ride Tech 2 way rear axle kit( 2 Gal Tank, Comp, Air Trap, 2100Ib Firestone double con bags)New
2" C-notch Rear Chassis(Boxed)
All Shocks Front and REAR (New)
TCI rear dropped spring kit with hangers,Springs , shackles(New)
5" Blocks(New)
U-Bolts(New)
Tail-Gate (New)
5 x Goodyear 4-1/4"W/W All weather Deluxe Tyres (New)
5X Powder Coated 16" 40 Ford Steel Wheels
46 Merc Hub Caps and Trim Rings(New)
Full Rear Brakes (New)
Original and very hard to find 1932 fire engine tail lights (Mint)
One off rear bumper with detachable tow bar...with locking pin and Alco ball(Elec's not wired)
New 1" bed wood with ratchet tie down points.
This list is just to name a small bit off the parts that have gone into the truck there is a lot more...this is not a show truck but a very clean original truck that can be run every day.
It has a few bumps here and there but all new powder coating and the bits that count.
Iv'e just MOTed it and the tax is in the window.
If you need to know more please call me (not E-mails) 07967 077160... Cheers Paul.
£15,000 otno (may deal on a Coupe) W.H.Y.
Del.... Truck is 6 -2" at the front and the seat is 50"...I put the shift on the column as me,Sue and Shannon can get in it..
Cheers P.
I'm getting a lot of mail on this...please if you are into it give me a call......also if you do want it come and have a look and a drive as it will answer all you are asking,,
Thank you for looking and all the good words...Cheers P.
