Putting my Dodge up for sale as work and family life keep leaving me short of time to work on it!
Lots of work done since purchase, truck runs well and drives, brakes are good, electrics all new, brand new smooth steel wheels and whitewall radial tyres, solid chassis and bodywork. Paintwork is poor. Very close to being usable but does need further work. Various new and used parts will be supplied with truck including the old wheels and tyres.
Price: £8500
Contact: Jon on 07942 689 051
Detailed description below...
TRUCK DETAILS
1956 Dodge C3-B8
1/2 ton Stepside pickup truck
C-Series "Job-Rated"
116" wheelbase
Big back window
241ci Polyspherical V8 (same block as early Hemi but different heads)
3-speed manual column shift
DVLA registered (with V5 document)
Tax exempt (currently on SORN)
MOT exempt
Owned since 2016, purchased from Rock 'n' Roll Motors.
ENGINE
Starts, runs well, good oil pressure
New water pump
New thermostat
New fan belt
New spark plugs
Fresh 20W/50 High zinc (ZDDP) oil
New oil filter
New flexible oil lines to/from remote oil filter
Fresh coolant
CHASSIS
Solid condition (needs painting)
New rear shocks
Rear axle flushed and refilled with new gear oil
BODYWORK
Solid sheet metal
Rough paintwork
New windscreen and rear window rubber seals
New Plexiglass side windows and quarterlights
Window winder mechanisms both working
Original "DODGE" and "Job-Rated" badges included - these are hard to find and horribly expensive! (badges not fitted, will be supplied in the boxes of parts)
Good wooden bed (new in 2017)
Good vinyl bench seat
New pressed aluminium number plates
Chrome door mirrors
BRAKES
New rear drums, shoes and cylinders
New copper lines and rear flexi
Rebuilt master cylinder with new seal
Recently flushed, filled with new DOT4 fluid and bled
WHEELS AND TYRES
New "Smoothie" steel wheels, powder coated in cream and with chrome hub caps
New Vitour whitewall radial tyres
ELECTRICAL SYSTEM
Fully rewired
New fuse box
New regulator
Dynamo fully working
New UK headlamp units (with integral sidelight)
New stop/tail/indicator lamp units
Original sidelight housings repurposed as front indicators
New fog and reverse lamps fitted
New twin-tone horn and relay
Original steering-wheel-mounted horn push repaired
New indicator/hazard, fog light and reverse light switches
Dashboard gauges refurbed and all working (fuel gauge fine when tested but no sender fitted to fuel tank)
Original 12V wipers fully working (new wiper rubbers fitted)
Good battery
FAULTS AND DEFECTS
Paintwork very rough. Truck was hastily resprayed in a very amateur fashion a few years ago, cellulose paint has begun to flake and there are small areas of surface rust in places. NO major rot though!
Radiator has slow leak from joint between top tank and core. Temporary repair using JB WaterWeld has slowed the leak but not stopped it entirely.
Small oil leak from transmission
Steering box working OK, but worm gear appears to have some damage to its thread. Likely to need replacement, upgrade to power steering might be wise as it's unassisted and quite heavy
No door cards or headlining
No fuel level sender fitted to fuel tank
Price: £8500
TRUCK DETAILS
1956 Dodge C3-B8
116" wheelbase
Big back window
MOT exempt
ENGINE
New water pump
New thermostat
New fan belt
New spark plugs
New oil filter
Fresh coolant
CHASSIS
New rear shocks
BODYWORK
Solid sheet metal
Rough paintwork
Chrome door mirrors
BRAKES
WHEELS AND TYRES
ELECTRICAL SYSTEM
Fully rewired
New fuse box
New regulator
Good battery
FAULTS AND DEFECTS
