Complete running gear from a 56 International Pickup showing 62k miles believed genuine
Running Silver Diamond 3.6L 220 ci Engine (needs a core plug available form Raock auto in the States)
3 speed manual with over drive
Prop Shaft
Rear axle - no leafs
Front I-beam on parallel leafs
RHD steering column, manual shift with steering box
All brakes were rebuilt by last owner and then parked for 2 years, haven't checked them. Stud pattern is mopar/ford
Engine was running last weekend before we started pulling truck apart, all parts available in the next couple of weeks.
Perfect rat rod or truck donor driveline
£500 ono for the lot or will split
Cheers
Gotzy
Discussion Starter · #2 ·
A bit more einfo, rear axle is 62" wide, 4.4:1 with rebuilt rear brakes
Front axle is off as well, wheels are still on so haven't measured or checked brakes but they would have been rebuilt as well
Would be Ideal for a full bodied Gasser
Banned
It was a SA import and yes it is red...
If it's the one i looked at in waterloovile before it went to portsmouth for storage i was told by the owner that the brakes were all landrover parts, might help you sell if people knew they could get parts ok,
by the way if it is the same one.......very nice truck you got there!
