1 - 11 of 11 Posts
hi there,
on my bronco 302 i get 50psi oil pressure on start up but after about 3-5 miles it drops to 25ish at about 50 mph and 5-10 on tickover. i get no rattles from the motor even under load i have fitted a new oil pump and i was wondering if a refresh of all the bottom end bearings would help as a cheap option or am i going to have to sell a kidney to get the whole thing rebuilt
rich
the other thing i was thinking about was keeping the oil temp down by fitting a cooler as i got one on the gearbox
how many miles has it done? new bearings won't hurt anyway :tup:
I would say you have no need for an oil cooler, a stock 302 shold not have oil temp problems, even if its geting old. You have fitted a new oil pump, was it a stock pump? It should be. A new set of bottom end bearings may help bring the pressure up, and certainly wont hurt it. The pressure you mention is a little low, but not for a 80000 miler, It not low enough to undualy concern me. But bearing cost for your engine is cheap so bung a set in. You are using multigrade oil? 20-50 is what I'd use in him.
Martin.
Hiya
oil filters can sometimes be the cause of pressure loss,there are lots of brands that are made to x amount of microns filtration and cause low flow=low pressure,iv even heard that fram have been known to be a culprit in some cases .may be worth a try to get a decent one from a performance parts supplier...
Discussion Starter · #8 ·
the oil pump is a standard replacement part . i have been using datona 20/50 multigrade mineral based oil which is for older engines so next thing to try is a different filter if that dont work then a new set of bearings.
thanks for all the advice
rich
Penrite recommend HPR40 for older 289s which is a 25w70 so thicker than most. Might be worth a try? I use it in a very worn out 289 and it does make a difference, especially when the engine gets hotter. Doesn't cost any more than normal oil from my local dealer.
daft question but what type of pressure gauge have you got? if its an electronic one throw it away and try a capillary type on it
New shells best option, or use a can of STP ( or similar) & thicker oil.
Your lifters will tell you when the oil pressure is too low!
1 - 11 of 11 Posts
