1971 440RB block, bored, just needs finish honing to your ring choice, main caps and bolts included, oil pickup taken out to 1/2
forged steel crank, has been fully machined, 3.750 stroke
hemi rods with bushed pin end for fully floating wrist pin, arp bolts and 12point nuts installed
high volume oil pump, with drive (2 of)
standard 440 sump pan
dual roller timing chains
timing cover
ive got 2 full rebuild gasket sets, 1 felpro, 1 mr gasket
genuine 906 fully ported and flowed heads machined for 2.14 int valves, 1.81 exh valves, new valve guides,
ive got the valves for street use,
solid flat tappet valve springs,
10degree retainers and locks
crane ductile adjustable rockers, 1.5 ratio, with shafts
M/T finned valve covers
1050cfm holley dominator
The 727 i was assured was in good working order when i brought it
i want to sell the lot together ideally,
£1500
you can contact me on 07723 927 024 thanks, Nick
