Following my last post about clearance issues between my Pete & Jakes shocks and the panhard mounting, I have tried sleeving the mount and grinding the rod but I still can't get enough clearance.
So, I've been scratching my head as to how to fix this. My latest idea is to remove the pin/mount and turn up an offset pin to replace it.
It looks like the original pin (the one on the right) is pressed in and located with a pin but can anyone confirm this? I really don't want to trash my radius rod!
Another issue I have is slack in the drive line where it bolts up to the rear axle, between the two big nuts. Is this normal or is there a way to remove this (bearing in mind I'll be running a 283 through the original trans and axle
thanks
thanks
