In the gutter
After a bit of fettling I got the panels to my satisfaction , spot welded them into place and with a bit more fettling they will fit fine. Corners need a bit of work , need some panel glue now to fix the Ali top panel in place.
Tried the original gutter (steel so can be welded on) with a temp screw to make sure hatch clears ,it might look a bit off but it will be needed . What do you think? thats if anyone is bothered to read this!
