Discussion Starter #1
Hi there
I have a leak from around the drain plug in the petrol tank, which I've tried to seal with various apparently appropriate products - but it works for a while, then eventually starts leaking again.
Anyone got any idea of an equivalent UK petrol tank that would fit if I wanted to replace? Don't fancy my chances of finding an actual Studebaker tank over here - and I suspect the cost of importing one from the States would be ludicrous...
Anton51Stude
If Steve Lang has any tank suppliers in the state's it won't be expensive to get one. Give him a call.
As Russ has said, it is possible to have a tank refurbed.
The usual procedure is to take it off the car [bit obvious, really].
It is then steamed out to remove any fuel residue to avoid explosive issues.
The tank is then dip-cleaned to remove paint, filler, crud etc.
Then the blow lamp comes out, as does a little flux and a stick of solder.
This is then used to ''tin'' the tank around the repair area.
A plate is then cut and tinned to cover the hole and sweated in place, creating a leak-free repair by running more solder around the plate's edges, its penetration being aided by capillary action.
I suspect that vibration or stress of some form [not corrosion] has started to crack the drain plug out of the tank, if so then it could be possible to do a repair yourself. It will probably not need a reinforcing plate, just a fillet of solder around the boss.
However, it cannot be emphasized enough that any fuel residue must be scoured out with steam [local garage got a steam lance for cleaning the underside of cars?].
I would certainly tackle it at home, as I do with radiators. Once done, it's easy and you wonder why you paid all that money previously. :tup:
