Discussion Starter #1
Big clear out!
Items available after the Hot Rod Drags (20th September) – come and see them in action at the track!
runs 10.3 all day long on normal unleaded or add 150hp gas and best so far is 9.4/142
GM 2-bolt iron block bore +60. Bottom end fully rebuild and sorted 2008.
Cast ‘049’ ported and polished cylinder heads, 2.19/1.88 stainless valves, large 7/16th dia push rods with guide plates. Crower stainless roller rockers, valve springs, guides and seals new for 2009 season.
Cometic MLS head gaskets, forged Speedpro high comp ratio (13:1) pistons, forged steel press fit rods, Total Seal gapless rings and Eagle forged steel crank (010 grind on mains and rods) Comp Cams Oval track high lift cam and solid lifters. Pete Jackson noisy timing chain.
Single plane manifold, fabricated billet rail ally valve covers, Moroso locking breathers, Moroso kicked out sump, CSR electric water pump, MSD crank trigger & matching dizzy, 11mm plug leads. £4500
FAST EFI - complete - £1650
Everything you need to go efi and all the advantages that go with it! As run successfully on the above engine, runs 10.3 on motor and return 20mpg – all on happy shopper unleaded!
Includes single plane manifold, 2200cfm billet throttle body, 55lb/hr injectors, fuel rails, all sensors – air temp, water temp, TPS, 1 bar MAP, wideband O2, classic FAST ecu all wiring and harnesses and even includes the FAST datalogger.
Happy to deal on the above two – and if sold together I’ll include 3 years worth of testing/logging on street, strip and dyno’s resulting in tunes for both street and strip, nitrous and N/A!!
Edelbrock Performer RPM nitrous system; Kit includes nitrous plate suits dominator pattern, nitrous and fuel solenoids( upto 400hp) 10lb bottle with hi-flow valve and bottle gauge, nitrous line from bottle to solenoid and assorted jets to go from about 50hp to 400hp. £350
1 pair Andy Robinson bottle brackets £100
NOS heater blanket £75
NOS Bottle blanket £25
NOS purge kit £75
Edelbrock progressive nitrous controller £200
1no 10lb nitrous bottle c/w hi flow valve £150
1no NOS big shot solenoid – in good working order hardly used. £80
A load of ancillaries also available after the HRD’s.
Jackson Racing built TH400 complete with deep sump and transbrake - rated to 800hp
Aeromotive A1000 fuel pump for carbs or efi: alky or gas
Aeromotive filter and spare element for above
Aeromotive regulator
MSD 7AL
MSD pro-power coil
Painless switch panel
Autometer Auto-Lite gauges – Speedo, Nitrous pressure, Fuel level,
emails to d.sidawayATsky.com
Call me on 07793 748 735
Dave
