401cuin 325hp Nailhead from a 1961 Invicta, 2sp Dynadrive trans, both prop shaft ends and rear axle.
Complete, as removed from a running, driving car about 8 years ago when everything worked perfectly. the engine and trans have been dry stored since then, engine has been oiled and turned over on a regular basis. The trans still has fluid in it that is very clean. The axle had the drums, back plates and half shafts removed for dry storage, unfortunately the casing and diff were stored under cover outside with polythene over each end but the damp has got in and there are 3 teeth on the ring gear that now have some pitting on them and the bearing housing on each end have some pitting also. I have cleaned them up and refitted the half shafts and the bearings have tapped in tight as they should do, I think they will be ok to use but felt it only fair to mention it. It measures 61" wheel mounting flange to flange, the ratio is 3.23:1
5" pcd 5 stud.
Included is a full gasket set for the motor.
Can deliver to Southern Swap Meet. (Will need a weeks notice to get motor out of storage.)
AXLE SOLD
Motor SOLD
Trans SOLD
Any questions call Ed 07932 800 904
5" pcd 5 stud.
AXLE SOLD
Motor SOLD
Trans SOLD
