1 - 6 of 6 Posts
Supercharged 461 cu in
Discussion Starter #1
im after a cheap twin 4 barrel plate for my 671 gmc blower. i am after one that is two 600vs in line (end to end) not side by side.
so to make it clearer.....the throttle linkages must run in one line down the left hand side of the blower when viewed from the back. Not like most of the one avail which have the linkages thru the middles
what you got??
what you got??
years ago, i fabbed one up out of steel, i'll post up a photo later.
the fabwork isn't great, but it worked, yours if you want it.
As promised, here it is.....
If you know anyone doing the hotrod and thrills this weekend, i can take it with me, failing that, i'm sure we can sort it.
all it'll cot you is postage.........and possibly a pint !
Discussion Starter #4
na sorry i dont know anyone goin there. that might be a bit high for what i want but will bare it in mind tho. If i cant get something sorted then i will came back to you. thanks for the prompt reply, and you said the fab wasnt that good....looks not bad to me. Top job:D:tup:
1 - 6 of 6 Posts
