the case will need re-tubing, as the shafts are for centred case not pinion
£125
the short side shaft, that came with the case = £50
pair of shafts 42 inch wide, centred pinion, need the splines cutting on them
£40
£150 the lot
-if you put some splines on the long grey shaft, you won't have to retube the case
