Banned
Hi again guys. My clarke 1 ton engine crane started leaking hydraulic oil after i folded it up for storage. I,ve had it a good few years and only used it a few times. Has the oil seal gone, and if so are they easy to replace, or is there a simple cure? Also, is hydraulic oil the only sort i can use? Cheers. Alan
Our work one has leaked for as long as i can remember, all you need do is lower the ram right down, half way up the ram is normally a rubber bung, take out the bung and refill with hydraulic oil, you may need to work the hydraulics a bit to bleed it through, sorted.
Heavy Oiler
To be honest, I send my rams to a hydraulic specialist for service. Would you want your engine suddenly dropping to the floor and smashing the sump, or landing on the cars bodywork as you lift it in?
Have you identified the actual source of the leak - is it around the ram seal itself or could it be from the low pressure area spilling oil as you have it folded down?
In my view - not the larger diameter round shiny slithery thing but somewhere else like a filler plug or the small pump piston (this isn't low pressure except when you have it folded down of course). Like Col suggests, it could be a good option to get it to a hydraulic engineering company as they usually stock seals and know what to do.
