a 3 speed shifter should work ok except because there is one less detent you won't be able to select 1st gear. drive position on the stick will be 4th gear in the box (o/d), 2nd position will be 3rd and 1st position will be 2nd. if you're happy not selecting 1st gear in the box you're all good.
pretty much what i thought (and how it seems to work with the current Lokar) - thanks for reply :tup:
