I'll be going to the Rot Rod Drags (if it's not pissing down).
Seriously heavy duty battery cables, complete with battery connectors.
The cables are 20mm external diameter but are surprisingly flexible with a silicon insulator. The terminals on the end of the cables have a 10mm diameter hole.
Red cable is 28.5" (724mm) between centres of the terminal holes.
Black cable is 13.25" (337mm) between centres.
Been trial fitted but never used as I relocated my battery. £15 for the pair inc. clamps
Mcleod Steel 153t Chevy Flywheel. I bought this about 1-year ago from Real Steal, I paid £288.62. It's been trial fitted but never run. I'll take £200 (bargain!).
[Sold] - American Racing wheels and cantre caps. 14"x7" 4 on 4.5" Will fit early, 6-cylinder Mustang or Falcon (and probably other stuff).
They're a bit scuffed and the lacquer is starting to craze a bit, but in 'not bad' nick - £80 for the set.
Here's what they look like on a Falcon Wagon (no, the wagon's not for sale)-
Hello
I think I want the wheels - can I check size and confirm tomorrow evening - thanks
Hi mate, really sorry but I've a had a PM from someone else and I've checked the times and he beat you to them by 40-minutes. Really sorry mate, but if that falls through for any reason then you've got second dibs.
I'll let you know.
