41 - 60 of 77 Posts
Discussion Starter · #41 ·
cheers Phil, as soon as pop gets on road i Will be back on the 34, old man has been gettin on with it at last, its just buried under all my filler dust at min ha ha
Discussion Starter · #42 ·
on the final flat down now before paint! - nearly there - cant wait to drive the bloody thing again
Discussion Starter · #44 ·
i like it in primer too! - still best paint the bugger spose! hopefuly finish flatting it at weekend and get any final bits done then get it in the paint shop next week or week after then try and get it all together in time for old warden!
on it boy!
Discussion Starter · #46 ·
terrible eyes!!! oh what terrible eyes - to be fair with all this dust its terrible eyes ears lungs and everything else hahaha!
not sure if you done that gag but please dont say it again my sides are hurting ;-)))
Discussion Starter · #47 ·
wahhhhhhhhooooooooooo its ready for paint - had a few issues with primer reacting - then a broken front wing ;-(( all set now tho - hopefuly paint shop can fit it in next week. Wheeled it outside to take some pics with me old mans heap today
Didnt see you at Old Warden this year, saw Dad though.
Good to see your car getting painted. What times does it run now with the Zetec
Ian
Lovin this.allways wanted a zetec turbo pop.
The water rail looks great need one for my zvh escort.
had any troubles with the water pump as the so called specialists say you cant use it as it turns the wrong way for rwd??
i think you are meant to use a water pump from an escort as the fins are different as it turns the other way on an escort
Discussion Starter · #51 · (Edited)
I used the original pump off the mondeo and it turns the same way - i just added an idler pulley on other side of motor and turn the water pump off back of belt. It works fine and runs cool.
Taxirod - i ran a 15.2 with it at hrd's with a real soft launch - i only got one run in tho. Its easy got a low 14 in it - and the boost is goin up whilst its off the road and going to get it on the rolling road - because at minute the ignition map is just a rough one done by myself. Would be happy with a low 14 but would love to see it do a 13.
sorry if you answered this already.
what mods did you have to do to fit the blower to the engine?
love the build looks sweet and proberbly one of my favourite colours to :)
Discussion Starter · #54 ·
the only mods to the engine for the blower was a de compression plate - home made manifolds and a megajolt ignition system. nothing major - as said its not running much boost at the minute going to up it before it hits the road again to around 8 - 9 psi. I think much more that that and the decompression plate would have to go and some forged pistons would be needed but it starts getting expensive then so the boost will be staying around 8 psi ha.
I like the colour too - i nearly got persuaded to change it this time but its gonna be the same again.
Its detonation that usually kills the cast pistons, which is a function of CR, how efficient your blower is/heats the intake air, combustion chamber shape, a/f ratio (I always shoot for 12:1 afr in a boosted motor), how robust the pistons are to start with etc. Some blowers when pushed hard just start to gain extra pressure by heating the air which is really bad for intake temps and detonation.
Ive ran cast pistons in a bike up to 16psi on ron98 and they survived but it had a really efficient combustion chamber for the use (flat top pistons, small hemispheric chamber and a large squish area) and 8.6:1 static compression, equally ive seen them when its gone wrong and detonated badly and it cracks the ring lands off the piston with the force. When the air was dense on a cool early morning test session you could just begin to detect detonation on wfo, so right on the edge of what was possible. Skirting the eternal abyss, like y'do.
Discussion Starter · #57 ·
We have paint........... got it back last night - still needs to be wet flatted and polished then throw it all back together wahooooooooooooooooooooo. excuse wanky photos from camera phone
Asbo, are you aware the ST170 focus has forged pistons and rods factory fitted. thicker headgaskets are available to lower compression too. years ago I did a budget 1800 turbo in my mk2 fiesta using a decomp plate. made a cracking cheap power source.
Dave
Discussion Starter · #59 ·
thats worth thinkin about in the future. cant wait to get it back on road now - bodywork has driven me mad
41 - 60 of 77 Posts
