81 - 100 of 149 Posts
Discussion Starter · #81 ·
i think the rover wheels actually suit it (y)
It's almost in the family isn't in, Austin Rover.... Funny how they suit it. It might just be that the wheel sits in the arch nicely, and any wheel would be good. I fancy a plain steel with a chrome cap but finding them in a 17" with a 4*100pcd is tricky.
you may end up with pcd adapters so you can use more readily available wheels. like everyone used to on volvo rear axles.
Discussion Starter · #83 ·
I've got a few hubs, later mx5, and kia that with a bit of messing around I might be able to use. That would give me 5 studs and open up options.
Discussion Starter · #84 ·
Morning all,
So, there's been progress but some of the photos don't explain it well.
Finished the rear of the chassis complete with bumper mount. (though the pic is work-in-progress)
630171
the top and bottom rails are now tied together, and there are threaded bosses for the bumper.
Discussion Starter · #86 ·
I then moved on to the seat mounts. This is built as a subframe from 100mmx50mm box. It's got to be strong as my seats have inbuilt belts. The threaded bushes go all the way through, welded top and bottom. There's also a 5mm plate on top for the seat feet to sit on. Subframe will be welded into the main frame. This gives me a good point to diagonal/K brace from.
630175
630176
630177
Discussion Starter · #87 ·
The seats angle in by about 2 degrees. The body tapers to the front so this was the only option- other than narrowing them.
Note, the feet perches hadn't been fitted in this pic.
630178
630179
Discussion Starter · #88 · (Edited)
I think you're up to date now, the rear frame and the seats have probably taken 3 weeks to get done but they're fairly fundamental and worth getting right to pass BIVA.
I ran out of gas, so that was the end of play.
Next job is to square the chassis up, then weld in the seat frame. More pictures once that's done.
Discussion Starter · #89 ·
I'm not a fan of all the plastic on these seats, but it's a compromise worth having. The plan is to keep the outside 'ratrod' but the inside/underside fully painted and trimmed, so maybe the seats will blend in better then.
Maybe I can trim the plastic bits with whatever material I do the door panels with to tie it all together. Ha! listen to me thinking about interior trim! Maybe I'd better get engine and gearbox mounted, and a steering coloumn, and a prop, and an exhaust, an ecu, some wiring, lights, glass, widscreen wipers...........
Discussion Starter · #91 ·
ok, slow to update...
Cut the floor braces out, replaced with new to give me space to fit seats
630435
had to cut the body side rails as well, but there's bracing to go back in there. This is for clearance of the seat mounts
630436
Discussion Starter · #93 ·
Now I know the limit to how far back the gearbox can go, I plan to stuff the engine and box in this weekend and maybe make some engine mounts.
Discussion Starter · #95 ·
Got a few hours in yesterday.
Had a look at my gearbox, thought it was a 6 speed, but it's a 5. Mine was a MK2, the MK1 is a lot easier to move the lever on, so I went and got a MK1 box.
Here's what they look like
630460
so, the simple thing to do is unbolt the remote, and bolt it back on using the rear holes on the mount onto the front holes on gearbox, shorten the shift rod.
I went a bit further.
630461
Cut the front off the remote (actually there's a section missing here as I'd trimmed it down by the time I decided to take a photo)
and then cut a new set of holes as far foward as I could. Had to mill a flat surface as well
630462
I realised I could add support by using the bit I cut off the front to pick up on the rear holes.
So, badly welded (I'll get it tig'd later) and assembled;
630463
150mm further foward than standard.
Discussion Starter · #96 ·
That last pic shows the MK2 box in the background. I'd hoped I could move the shifter fwards to that inspection cover, but under that is the reverse lockout, and the centering springs are all in the rear housing which I'd have to cut off for clearance.
I think there's a possibility that the MK1 tail section would bolt on to the MK2 box, but I can't see any gain there apart from I know my MK2 box has done 80k miles.
Discussion Starter · #98 ·
Next job might be to do the lower diff mount now I know the pinion angle. or I might do the steering column. Now the engine's in there's a realisation that if the rack was rotated so that the input spline is horizontal it will clear lots of stuff. Shame really as I spent a while hacking the front cross member about. Once I've got those 2 sorted, I can crossbrace the rails and do the finish welding.
Discussion Starter · #99 ·
For the steering I could do with a steering shaft to suit escort splines that's at least 400mm long. Any ideas for a source? I'll support it at the non-rack end with a bearing then UJ up to the mazda column. I'll need to convert from escort to Mazda splines along the way somewhere.
How would IVA view a welded column extension- mazda female spline, ford male spline?
rally design keep splined each end escort column shafts and metre lengths of tube that's a good fit so you can lengthen them. re biva, if it's welded and painted neat it won't be obvious that it's altered. and it's not altering a factory original austin part. as an example mk3/4 escort columns are welded at the ujs under the dash to get the needed offset.
just had a thought i seem to remember car builder solutions do a 400mm shaft, worth checking.
