an update, as it seems I've been away for a month!
Combination of lots of domestic stuff to do and a loss of mojo.
I'm at the stage in the project where the 'big stuff' is done so I've not got those tasks to sink my teeth into. However some of the smaller jobs still take hours!
It's come back a bit now as I have some direction.
There's also the slighly demotivating part of having to take it all apart (wings off, bulkhead, pedals, engine out, body off, etc)
to do the next job. It only takes half an hour, but it goes from looking fairly complete to a bare chassis again!
Stuff done in the last few weeks:
1/ Cut the rear chassis so I could pull the lower chassis rails straight. All done and the body mounts line up again. Just got to check the diff pinion angle as that might have moved a touch. Not finish welded yet, I'll wait till I need to pull the body off again.
2/ Exhaust all made- apart from an end can which I'm not sure it needs. Stainless welding with the mig went very well. I could grind them back and polish, but, it's an exhaust.
Even all the rubber mounts done. It's the fiddly bits that take time.
3/ Handbrake cables routed and fixed to chassis, new extended front cable made., including a couple of delrin bobbins to stop it flapping about, and the captive thread in the chassis. Need to get a custom cable made for one side as it's got to run much further than on the mx5, and has to clear the exhaust.
4/ Fuel system worked out. There was a bunch of pipes, a solonoid, a boost sensor(?). Pretty much all can go as it's just the evap system. When all boiled down there's just one feed from the tank and no return. Simple. I like simple. Made a braket for the fuel pressure reg which now gives me a landing point for the pipe from the tank so I can run that. I could have used the MX bracket, but, well, mines smaller, and rounded, and, I like to mess about.
So will be continuing fuel system for a while, including making the tank. I've salvaged the in-tank pump and sender from the MX.
