V12 ETYPE auto box and torque converter!
I have just come to put the converter on the box and the two locating tabs on the converter where it mates with the pump I expected to see two recesses in the pump to locate the converter
Instead I just see two small tabs on the pump. So when I put the converter on it turns 100 degrees before turning the pump. Is that right??
Its never plain sailing!!!
Official Drag Addict....
sounds ok to me.
ive got a workshop manual somewhere in the garage ill try and find out more in the morning.
have you had it apart?.
Sid.
Yes I have it apart now! I just thought the two locating pegs, on the converter, has they went into the pump, fitted snuggley in to two resses's within the pump. If you have a look I would appreciate it thanks
DC
drag race addict
That's how they are. It was designed so you could put the converter and bellhousing on the engine first,then put the trans on the bellhousing afterwards.
Yes I have it apart now! DC
i kind of figured that mate..;)
i meant the gearbox but it seems Mr Frost has put your mind at ease?
couldnt find the manual btw..
good luck..
Sid.
ps. what you putting the engine/box into?
Thanks
It just seemed odd to have 'slop' on the auto box pump.
Thought I would check with you guys 'The people that know' thanks Andy
And thanks again for taking the time to answer
Regards Dave C
I am putting it back in my series 3 V12 E TYPE been restoring it the last 2 year. Has soon as it is done the PoP
gets it lol
drag race addict
Regards Dave C
gets it lol
No problem Dave..:tup:
