The glass eventually arrived and I mounted the winder mechanisms, window goes up and down nicely, result. Hmm, not so quick.....when I try sitting in the drivers seat, the winder is right where my knee goes. And due to the tight confines, my knee can only go in one place.
So I managed to relocate the mechanism to a place which didn't conflict with my knee, and thankfully still wound up and down smoothly. Then I finished up work on the door panel and fitted that, quite pleased with the look, but, next issue, can't get fingers between steering wheel and door capping comfortably. I tried this way back when I fitted the steering column, I was convinced at the time it would be ok. So a bit of a tweak to the door capping is now on my job list.
Another similar problem, now with the door card on, I can't get my hand on the handbrake, I cured this by cutting out the hole you can see on the bottom half of the door card.
The hole at the top is where you put your hand through to pull the cable which opens the door, similar to the original Ruby set up.
Ive also fitted a door pocket to create some much needed storage.
Next I need to complete the same stuff on the passenger door.
Passed MOT this week with no advisories.
