1 - 20 of 21 Posts
Chuckinmuck since 1966
Looking to reposition battery on a van, thinking of bolting it down behind drivers seat and boxing it in with MDF, with a vent through floor to vent any nasty gasses.
Am I missing anything here ?
Will I fall foul of any MOT regs ?
Thanks in advance
Hmm, slight hijack so apologies to chevy chaser - I was planning to move battery into either boot or maybe under rear seat. i hadn't really thought about any mot or venting (execpt i know it needs to be secure) so whats the general do's and don'ts then?
Also is there a kit for relocating?
I've got an 05 Transit and that's where Ford put the battery so it must be OK.
Rog.
I've remounted mine behind the bench seat in the truck, I have accidentally found a brilliant battery box for it, went to the local breakers for a proper box and baseplate, second car I lifted the bonnet on was a rover 75, Not kidding guys, you could not design a better item, steel base plate, with bolt holes to mount, this sits inside a plastic 5 sided box with cut outs for leads, and a fixable top with vents and an adjustable strap to secure the battery in the box. Its brilliant, all for £5, mind you the yard I go to, the old and I mean old, guy who owns it, still prices stuff like the 60s and 70s.
As regards mot, its just got to be secure and have no bare wires showing. position is up to you, I wanted it inside as now the truck is diesel, heavy outdoor condensation seems to take its toll on batteries.
Legally It has to be fixed securely, and it has to be airtight against the passenger compartment (battery fumes are highly explosive! - hence vent to outside air).
so any large bmw or merc is illegal?, under rear seat, beetle under seat?
Semi Proffessional Prat
Rog.
They started that in 57 with a Thames. It was a feature in those days.
I'm a grown up drunk!
My work van, 07 Citroen dispatch has the battery under the drivers side floor,
Pretty much directly below my right knee,
Only covered by a clip in floor panel, certainly not air tight.
Heavy Oiler
Landrover have positioned batteries under the front seat 30 years before gel batteries were invented..
I use gel batteries though on all my cars as I don't like the thought of nasties like acid and vapours.
Yeah but to be fair, They are vented to FRESH AIR!, never seen an airtight landy in my life. :incheek:
1 - 20 of 21 Posts
