454 Big block performance Engine:
Block number: 14015445
1987 Gen IV / 2pc Main seal / 4 Bolt Main.
454 Core Block low mileage 37'000 miles RV Engine.
Now Fully machined 030 over / Fully deburred & VHT Painted Block /
Cam Bearings Installed and New Camshaft test fitted.
Full Eagle Street Performance Rotating Assembly
Stroke: 4.000
Disp. @ .030: 460ci
Rod Length: 6.135
Pistons: +22cc Dome
Rings: Standard Gap
Comp. Ratio 112cc/ 118cc/ 124cc: 10.1/ 9.6/ 9.2
Eagle I Beam / Hypereutectic Pistons / Eagle Crankshaft / Flex-plate & Damper Fully Balanced /
Hastings Plasma Moly Rings / King Con-rod bearings / King Main Bearings
Holley Street Avenger 770cfm (needs new Electric choke case, very low mileage carb, very clean)
ARP 4 Bolt main kit
Comps Camshaft XE274H
Comps Magnum Double Roller Timing Set
Comps Block Hardware Kit
Brass Core Plug Kit
Mr Gasket Cam bolt Lock kit
Melling Oil Pump
Melling Oil screen
Fram Oil Filter
Milidon Balancer Bolt Kit
Moroso Fuel Blank Plate
Full set of New Hydraulic Tappets
Fel pro one-piece Oil pan Gasket
Chrome Oil pan
Alloy Timing Cover
Full Stainless Steel Engine Bolt Kit
New Edelbrock RPM AIR-GAP Manifold
New Alloy Polished water pump
Moroso Water pump extension kit Short-to-long
2 x 160 degree thermostats
New High Torque Mini starter Kit with bolts
1 x Billet Dipstick 1 x Standard Dipstick
Manifold Vacuum Fitting
Fuel pressure Fitting
Chrome Alternator Bracket
Lower Gasket Set
Fel pro Valve Cover Gaskets
Manifold vacuum seal Fittings
Spark Plug indexing Washers
Carb vacuum plugs
Mr Gasket Timing Tab
Mr Gasket HEI Advance Kit
Mr Gasket Lead Separator Kit
Comps cam Oil Break-in Additive
454 Chrome valve Covers
Good Set of Hedman Exhaust Headers with 3'' Collectors
Original set of Low Mileage 454 Peanut Port heads Supplied.
Great Spec Big Block for easy 500bhp+
Ready to Assembly, only needs Distributor, Flex plate Bolts, Leads,
Spark Plugs and a Good set of Heads to be a real powerhouse in any street Machine.
There's many low compression Stock Big blocks floating around on eBay, but this Combination is capable of 500-700bhp
with the right set of Heads, Excellent street Compression for Edelbrock & Pro comp Cylinder Heads,
Taken along time to peace together, so not going to Accept silly offers.
For the Buy it now price of £3750
I will build the Bottom end for the New Owner.
I Can Deliver at Buyers Cost.
Cash on Collection or Paypal.
TEL:07972025719
[email protected]
www.publicenemycustoms.uk
