1 - 11 of 11 Posts
BIG BLOCK CHEVY CRANE CAMS,
SOLID LIFTER CAM AND SOLID LIFTERS IN EXCELLENT USED CONDITION DYNO TIME ONLY,
SPECS 600 INT 620 EX DURATION 310 320
A MAX TORQUE CAMSHAFT FOR LAUNCH
HIGH UPPER RPM POWER TO PULL THROUGH GEARS RPM RANGE 4,000 TO 7,200
MECH LIFTERS 99250-16
CAM CRANE CRN 134762 GRIND NO CC-310
THIS PACKAGE WAS OVER £500, YOUR BARGAIN £200.00
BIG CHEVY VALVE SPRINGS NEW, DUAL SPRINGS 99893-16 SPRING RATE 391LBS, NEW UNUSED,£100.00
THANKS FOR ADD RODDERS,
07974 088375
hi
the lifters are all marked to the appropriate cam lobe, yes the cam was broken in, but if i were fitting it i would use some break in lube as extra insurance or at least get some oil with the zinc in or add a pot to your oil.
thank you,
Discussion Starter · #6 ·
Hi i would hold it you with a deposit say via paypal or something, i sure dont mind doing that if it helps you out for a month or something,, i dont know what you might have as a px i can use ,, i suddenly find my self needing an alternator for a 302 in a mk 2 mustang 1976 ????
1 - 11 of 11 Posts
