541 - 560 of 567 Posts
Discussion Starter · #541 ·
i dug out the super stock scoop today and sat it on the air filters to get some idea of how much taller it'd need to be. that'll be about 2 1/2" then......mmmmmm.
i may cut it up a lot and narrow it at the same time, it won't ever look like what it started as so may as well see what i can make work. either that or i make/buy something else entirely. i think first job is cut the bonnet, get that fitted and go from there
:thumbright:
Discussion Starter · #544 ·
ashley said you must have a youtube channel as you put a video of your anglia on there, so after a quick search i found this
Discussion Starter · #545 ·
the last 'wasted' part of the interior is the upper dash pad. i just ordered an ACCU-Form dash cap which should tidy this up nicely.
Discussion Starter · #546 ·
i made a start on the hole in the hood today. first was to make a template that fitted pretty close round the carbs etc, i drew underneath the card holding the sharpie vertical (ish). then transfer that to the hood with measurements and finally the first cut. i've cut slightly smaller on purpose, you can always cut more but if you cut too far one way due to a cock up with the measuring then you're done. next job is get ashley here to help me bolt it in place for final trimming.
Stroker
Mill sounds lush :love: (y)
  • Like
Reactions: mygasser
Discussion Starter · #549 ·
i've started the hybrid valiant/explorer handbrake cables today. i removed both rear cables so i can lube them before use (see pic) and i'll also reroute the front cable inside the chassis so it won't be in the way when i get round to doing chassis/frame connectors later on. i cut the 'loop' off of the end of each explorer cable and these will be welded to the valiant cable's end nipples. i'll need to make a couple of tube spacers as the cables look like they'll be too long otherwise but that's easy enough (already found some suitable tube).
plus while looking for core plugs for clive's 383 i found one or those mr gasket stainless sleeve/chrome bracket coil cover sets so i fitted that to my black coil. i know i'm a tart, i even dug out a 'right size' brass core plug that fits in the end of the sleeve too for full poshness.
Discussion Starter · #550 ·
handbrake cables made up and fitted and front cable rerouted inside the chassis. i had to unwind the valiant return springs off of the cables and wind the stronger explorer ones on instead. handbrake now works, tick.
ashley came round after work and we fitted and trimmed the bonnet so that's done too, woohoo
Discussion Starter · #551 ·
so, i have a few jobs to do for a mate on his cortina mk5 that will be easier on my lift. i've told him to bring it here next weekend meaning i have a week to get the valiant driveable so i can move it to my new garage over the road. ya gotta love a deadline 😁
Discussion Starter · #552 · (Edited)
i went out to measure for the rear brake flexis earlier and remove the fittings from the explorer calipers and valiant T piece so i could get braided hoses made up at rally design. the explorers have a short flexi one side from the caliper then a hard line to the T the other side which doubles as the end of the flexi that side too. the chassis to axle flexi to that T is crimped to the T so as that was cut my plan was to replace both sides from the calipers to the valiant T with 2 longer braided flexis.
first though as i'm tight i thought i'd look to see if there was a way to blank off where the cut flexi attached to the explorer T. so after filing the brass block flat i drilled and tapped it for an m6 bolt, then made a copper washer from an offcut of my header gasket 2mm copper sheet.
so now i have 2 flexis i can use and i only need to attach them, the valiant T and a couple of shorter hard lines and the brakes can be bled. all with what i have here already and no money spent. (y)
Discussion Starter · #553 ·
today so far i've unbolted the rear axle for a few jobs to be finished. the perches need welding fully (i tacked them today), the front spring hangers needed drilling for 5/8" spring eye bolts to suit the ss springs and the shackle bushes are being replaced with poly bushes from prothane. once that's all done and refitted i can start running/making brake pipes and welding on tabs/bolts to secure them. pics later when i'm done for the day.
Discussion Starter · #554 ·
i had a good afternoon and it now has brakes and the clutch works too. reassembly went as expected and the brakes bled easily giving a nice firm pedal. i trimmed all the wheelnut shanks and wheel studs now the wheel fitment is finalised, i'd just doubled up on washers for mock up so that needed doing. making the brake pipes was easy as always, the right tools make all the difference giving neat perfect flares every time.
seat mountings are next and then it's driveable, looks like even with diy jobs to do i'll have it mobile by the weekend as planned.
:thumbright:
Yup the right tools make a world of difference , I have one of those Sykes flarers and I think its the best flaring tool you can get. Fast as well.
Discussion Starter · #556 ·
yesterday and today i've been altering seats to tilt forward and making my own hurst shifter to inland shift lever adapter. i've decided to use the mercedes seats instead of the scorpio ones as they're just more 'recaro' than 'chesterfield sofa' if you get my drift. also the runners are nice and flat side to side unlike the scorpio ones which had very 'uneven' brackets. getting them to tilt was similar to the scorpio ones though, there are 4 bolts holding the backrest rigid so simply remove the rear 2 and loosen the front 2 and they tilt. the front 2 are loctited in their new position so they don't loosen and the seat base is a metal tray so the backrest bracket just sits in the tray. to suit the valiant floor i needed to make 1 2" tall spacer for the inner front bolt and drill 3 holes (the outer front bench seat hole is reused). i'll add (weld in) some 2mm plate under the inner holes as there's no strengthening there where it was a bench seat car. i've altered the second seat ready to fit hopefully tomorrow along with the new carpet. oh, i guess i should see what needs 'adapting' to fit the mercedes rear seat too.
next once the drivers seat was bolted down i made an adapter to mount my inland shift lever/stick to the hurst shifter. pretty easy, just a plate to bolt to the shifter with the top cut at the correct angle for a second plate to weld to it which is threaded to suit the inland lever bolt pattern. i removed the reverse lockout cable, button etc and grount the 'triggers' smooth before painting the lever with some silver and clear lacquer as the chrome was fubarred.
Discussion Starter · #557 ·
ok, back seat then and not too bad a job as it turned out. i had to make a pair of risers to support the front of the base up to tunnel height. i welded a nut behind where the seat bracket hung down each end and a flat sheet hook that the rear hooked into to stop it sliding down and forward. the rear sections (it was a 60/40 folding seat) have a thick flat plastic backing (about 1/4" thick) as the seat belt is fixed inside so strength is important. i'll be using lap belts in the back so don't need them. anyway, i'll need ashley to help mounting them as the plan is to hold them against the seat/parcel shelf frame then drill through the frame and use fat self tapping screws through into the plastic backing. the 2 side pieces that cover the inner wheel arches will need the foam sanding back to suit the shape and sit back neatly, i can't do them until the backs are secured though. i was lucky and height wise they are spot on, about 3/4" higher than the parcel shelf.
last job today was the only bit of rust through i've found on the car, 2 tiny holes on the passengers floor. or at least that what it looked like until i started tapping at it with a pointy hammer to remove any flaky rust in the area. i ended up with a section about 4"x6" with a couple of ribs in (1 short and 1 full length). i'll clean up any whiskers underneath next time it's in the air and get some sealer and paint on it.
oh, i nearly forgot i added the lsd additive and gear oil to the rear axle before i forgot too.
Discussion Starter · #558 ·
i'm taking my grandson the the dentist to have his brace altered in the morning so i've roped my daughter in to help secure the seat backs in place when we get back
:thumbright:
i just need to sand the foam to get the side cushion/bolster bits to sit right and it's done.
then if she's not in a rush i've got a large sheet/roll of 3/8" foam rubber which we'll cut into panels to use as carpet underlay for that luxury feel
:D
Discussion Starter · #559 ·
today my daughter terri helped me with the rear seat fitment. we must've had the backs in and out 4 times. getting them secured was the easy bit, the side bolsters took the time. after sanding the foam to conform to the shape of the valiant inner arches we ended up with some angle brackets made to support the upper steel loops inside and bent the lower ones to attach to existing tabs sticking out of the bottom of the inner arch. while it was out i sprayed the green parcel shelf board black to match the seats. tomorrow i'll remove the driver's seat to mark and drill the passenger's floor then start laying underlay and carpet. no pics as the seat looks as it did at mockup.
Discussion Starter · #560 ·
first job today was remove the driver's seat and measure the new hole positions on the floor so i could drill the passenger's side. with that done i cut some foam panels for the floors as underlay and taped these in place with ally tape. i layed the carpet out in the sun while i cut, drilled, welded and painted black the reinforcing plates under the floor where the 'new' bolt holes are now (i don't want the floors splitting later). then i layed the carpets in the car and removed the sill/rocker trims and kick panels. there's enough 'spare' at the back to cover the new seat risers i welded in for the mercedes seats which was a nice bonus. it's sat there now and i have started trimming on the passenger's side but it was really hot in the garage and my back had enough so i called it a day. i did get one of the kick panels painted black, i'll do the other tomorrow and hopefully i can finish it all up and fit both front seats back in for the last time.
