If it's a single carb you are after for a reasonably small motor, look at Renault 5 and Montego turbo ones.
For twins, look at Lotus stuff.
Hi,
If you can let me know as much of the following as you can I will see what sort of deal I can get from Quickfuel for you,
Cam duration at 50
Gross lift at the valve
Rocker arm ratio
Compression Ratio
CID
Head Type and valve size
Head flow if possible
Car weight
Gear Ratio
Convertor stall
Trans type (OD?)
Max Shift RPM
Current carb type and size
Fuel Pump Brand and Size
Filter types and location in fuel system
Fuel Line sizes from the cell to the float bowls
Inches of Manifold vacuum with idle timing set at 30* with or without Vac line connected
Type of distributor ...with or without vacuum canister.
Ignition box- Daytona CD1, Crane, MSD
Dual or Single plane intake
Headers and tube size
Jon
