I have 3 door Cosworth 4 pot calipers up front and 285mm discs with Sierra rear calipers and Fiesta discs, running a servo on my Corsair. Having problems with master cylinder sticking at the present so planning a change to a new one (re-rubbered but no difference) so what size should I be looking for in a new master cylinder please? Would like to get rid of servo too so what size then? Paul
You'll hav eto completely redesign your brakes if you want to lose the servo as the m/c bore required will not create enough line pressure. Normal way would be tiwn cylinders on a bias box.
I take it you are currently running single circuit with remote servo ?
Yes single circuit, losing servo not high on the list just want empty engine bay. Will just locate it elsewhere. Do you reckon a one inch cylinder will work OK?
Got 7/8th one on at present. Paul
