I have this M10 brake T-piece and want to replace it.
Who stocks this type?
It has male internal fittings to suit my female flared brake pipes
The ones I see for sale are all female internals.....I don't want to alter my pipes to suit but simply replace the T-piece/
Hope someone lets me know
Finger Wood Material property Jewellery Rectangle
Fluid Material property Wood Household hardware Gas
where to buy one.
Hi Kev
I have another T-piece and that has a different internal shape ........it slopes inwards, cone shape, like it would suit a male flared end.
The one shown is quite different internally ( that central prt protrudes) to suit a different flare which I thought would be to suit a female brake pipe end
perhaps I'm having another senior moment and canne see it.
I see what's happening ...terminolgy problem . The difference is that the one you have in your photo would require OP2 as well as standard OP1 for standard male fitting . Don't think I've ever seen one like that in all my 50 years playing with cars . What's from ? ie can you get a replacement from OEM?
Same here Kev........that's why I asked on here.
It had me well puzzled. Eventually went with standard female T-pieces and made up new pipes to solve this.
I had ABS system problems with this and decided it was easier to go with a 'normal' servo so had to join pipes
to suit the master cylinder instead of going to the ABS block.
Something a bit different...........
You been messing again ? LOL Nope, struggling to recognise the base car ??
Most US vehicles have that sort of tee, all pipes inc flexy ,need to have OP1 and OP2 "type" ends
Some flexys seal only on a flat washer
