hi
i have fitted disc brakes to my f100 56
and a remote servo and residue valves
now as i drive ,the brakes over time slowly start binding
so i have taken off the rear residue valve still the same
some one has said it may be the hose from the manifold to the remote servo may be collapsing
any help would be great
thanks richard
hi richard,
first thing i can think of which is the most common i've come across for this same issue was the master cylinder hadn't released fully,
in not coming back off it means you've got a hydraulic lock essentially which is ok till things warm up and expand then the caliper grabs the disc, more and more till it can lock on....
so in essence make sure the pedal is actually releasing FULLY.has it got a nice strong spring on the pedal?
obviously when it is the fluid is able to flow back to the master cylinder so no problem.....
neil
:yeahthat: the first thing I thought too. I replaces a m/c and the pedal wasn't completely releasing. It wasn't really noticeable until the brakes were used and they gradually locked on.
The servo just helps alter the mechanical effort required to apply the brakes. Even with a failed servo the brakes will still work without issue the pedal will just feel heavy.
Another option is check all the flexi-hoses. Old ones can internally collapse.
