for sale a pair of brembo 4 pot alloy calipers , as used on mitsubishi evo, subaru imprezza, range rover, they are as removed with part worn calipers and some titanium brake shims, pistons move ok . bright red in colour. needs 32mm wide by 330mm discs , from evo or bmw 7 serires etc. £150 pair
copper and brass radiator with plastic ends, overall width 29" x overall height 15" with 1 1/2" radiator pipes, was used to cool sbc in drag racing 100e very little use, very clean inside just a few scratched fins £15
2 -off exhaust boxex straight through in mild steel , boxes 5 1/2"diameter x 11" long, exhaust tube outer diameter 55mm so should just fit over 2" tubing, tubes stick out 6" from each side of boxes, never used £15 pair
parts near loughborough can call on 077459 12248
cheers nigel
