Hay every one I'm new to this as u will find out with all the questions I have :/
To the point --- I'm think in about using a landrover chassis and runing gear but with a jaguar body I'm just wondering what I would regester this as I have read all the DMV info but still found myself left wonting can any one help. All info is welcomed. Thank u preemptivly
I'm selling a tax exempt LR chassis right now ;) shameless plug! Also have axles that can go with it if needed
And you'd register it as a landrover with a modified body, the landrover chassis is worth 5 points, axles are 2, suspension 2, steering set up is 2 as well I think then engine and drivetrain are 1 each
starting to crawl back up
welcome
that would come under the class of a re-body in my book so it would be a landrover if you used the chassis n, running gear
kev, =Kapri on here will be able to inform you better he,s the font of knowledge on these matters.
