This water fountain is antique as can plainly be seen. The base is cracked all the way around. Must weigh 500+ lbs.
How How do I repair it?
631892
631893
631894
I did mine with a mig welder using videos on you tube I had no way to reheat apart from a heat gun,Mine was fine but it was a cracked handle for a press ,so no real load bearing I had to grind the crack into a V to accept the weld and im not a very experienced welder.
