Probably a dumb question, but can someone please school me on the principles of this type of gauge please? I've used the electric gauge & sender versions on previous engines, but never a mechanical one. I have a nice gauge that has about an inch of the copper wire sticking out the back, and I don't know whether to use it or not until I understand how it works.
Thanks guys
Banjo snapper.
If it doesn't look much like this one, it's had the sender bit chopped off, pretty sure that makes it cattled.
"call 0-800 Apocalypse"
is it part of a cluster,ie speedo.oil.temp,fuel,amps,ect? it may be possible to replace just the fucked bit, can you post a pic?:tup:
Banjo snapper.
As I thought, cattled.
You can get them repaired.
They fit a new tube and bulb, with the appropriate fitting for your engine, but unless it's a classic gauge it's not worth doing, as it's cheaper to just buy a new one.
Discussion Starter · #9 ·
Thanks for your help guys. Miles, I tried ringing you yesterday afternoon because I wondered if you did keep them there. Will try again later. Thanks again
