I was thinking about making one myself, like I did with my last car, but a bit of research turned up this bad boy:
It's a landrover fuel tank, bog standard, bought new, straight from the dealer in Cannock. Cost was about £55. It holds ten gallons and has fittings for a standard Landy fuel sender, to make life easier. Underneath is a single tapped hole, about 14mm, or some such oddball thread, but I tapped mine out to BSP size for a hydraulic fitting.
It comes welded to a 1/8" thick steel base plate, so modifying the mounting brackets is easy without running the risk of burning through the tank.
The filler cap was found at a boot sale, but the tank comes with 1 3/4" hose stub.
I have already fitted the brackets to mount a second one to the other side of the boot, should the need arise.
Official Drag Addict....
have we seen this before in the same car?
sometime ago?
good idea all the same...:tup:
Sid.
Same car, different channel. :D
thought so... youll have it nearly finished by now then??...:tup:
we want update pics....:bigsmile:
Sid.
Sid.
It is currently pulled apart while I do some filling and stuff ready to whack a coat of paint on the body, then it'll be ready for assembly, wiring, brake lines, fuel lines, interior.......
Another couple of years then I guess :smoke:
I'm in need of a complete running C6 tranny for an FE big block, if anybody has one laying about.......
