It all went swimmingly at Reaper Towers this weekend with lots ticked off the 'to do' list.
I spent a day on the links. No, not the golf course. I haven't played golf since that incident with the bloody windmill.....
So I made these link bars. Ends are threaded LH and RH to make adjustment easier.
Long bars are the rear axle trailing arm links, short bars are the front diff support links (mandatory here in NZ):
Rosejoints came to me as a gift. Apparently they had been supplied wrongly. Either way I was happy to accept.
They are 5/8 unf threads (LH & RH) with a 12mm bore in the ball:
With the help of these brackets (made from 3mm steel plate) and some spacers turned from 6061:
They attach to the front of the hub lower pivot and shock absorber like so:
Inner mount brackets need to be made, but they will weld to the cross-tube at the top of the photo.
Front diff link bars bolt to the front pivot link plate (made in a previous exciting episode):
And will link up to the top of the chassis, thanks to these little mount brackets which will be welded in place:
And whilst I was getting all excited with tubes, rosejoints and brackets I made this front chassis brace:
All to be welded at a later date....
BUT THAT'S NOT ALL!
Oh no!. Due to the fact that I'm going to have to wire it up at some stage in the (hopefully not too distant) future, I put a cheeky bid in at a local auction house and got all of this (and more stuff including woven nylon wiring sleeve in 4 different sizes) for a HUGE $30!
So I spent a bit of time setting up a wiring station using a workbench that I don't really use any more:
There was more, but nothing really photo-worthy.
