I love my plasma cutter
I am after a Chevy rear axle 60" ish wide wheel face to face, I don't need an L.S. just normal.
Also a Prop shaft to fit Camaro 5spd manual box 27 spline. and I'll give you some money in return.
Got one now, thanks..
Essex.
The prop you can have made to measur for not a lot of money.....which you will need to do anyway. I don't have an axle but knowing what gear ratio you want will help in your quest
a mate has a lincoln town car 8.8 axle. 64" wide but ford pcd of course. it is lsd as a consolation.
Discussion Starter · #7 ·
Gear ratio not a problem. as long as it's not lsd or independent.
