Hi thought I would quickly introduce myself on this forum,
I have recently reconditioned a few Chevy 350 V8's and am looking to sell them. I have 30 years experience in building these engines and am a precision machinist these engines are built to a very high standard and I offer a 6 month warranty if the mechanical elements are left unchanged.
The engine specs are as follows:
Block casting no 3970010 4 bolt mains, Re bored to 0.030
Crank casting no. ZZZ 1183 Forged Steel Crankshaft, Ground to 0.010
Cylinder Heads Casting no. 333882 76 cc fully rebuilt, New Stainless Steel valves 1.94" inlet & 1.5"exhaust, Cylinder Heads Ported and Skimmed.
All new Fel-Pro gaskets and seals and assembled with Stainless Steel Allen Cap Bolts
Forged TRW Raised Top Pistons and Rings 0.030
New king Bearings on 0.010" mains and Big Ends
New Clevite Cam Bearings, Double Roller Timing Chain kit
New performer Cam Shaft with lifters
New High Volume
Oil Pump
Long water pump
spark plugs, Plug Leads & holders
New Ally pulleys & Pro street Crank Damper & Fan Belt
New Edelbrock air cleaner
Oil Switch
New Core plugs
New PCV valve
New Crank Nose Bolt
New Thermostat & water outlet
New Alternator Bracket
Victor Junior 4 barrel intake with 1" Carb Spacer
New Camaro ( 1967-1969 ) 4 Into 1 Headers used in Most Applications
New HEI Distributor
Victor Junior Intake with Edelbrock 670 cfm 4 barrel carburettor
Starter
New alternator
New Chrome dress up kit
New sump and Oil pick up pipe
Auto Flywheel
Can be seen running on my test bench and can give you a quote if you need the engine palleted and sent to your door.
Selling this for £4150
If you are interested please send me a PM or phone me on 07739579715
Thanks
4100 need to see it gone this week, open to offers
thanks
