Hi, Still looking for a set of standard height spindles with discs / callipers for a first generation rear steer Camaro 1968 or any other Chevy rear steer (the steering ball joint fits to the arm on the back side of the disk) as I think many are interchangeable. Also seems I could use front steer ones if the spindles and steering connection are in two bits i.e. not cast together. Even a set of the brackets that mount the callipers as I may be able to adapt what I have ( on lowered spindles at the mo with single piston callipers ) any bits considered.
Cheers Norm
bump
