Up for grabs are these Coilover shock mount Kits.
They are made from 6mm Thick mild steel laser cut main plates x 2
4mm thick laser cut mild steel shock plates x 4
2 x half inch unf bolts and 4 x unf shock mount plate bolts all with nylock nuts.
These are new kits that require welding to your axle. The axle mount is for a 3 inch axle casing such as ford and chevy axles.
£49.95 plus P&P
There are various ways to mount to your axle giving 12 position adjustment.
for more info call Bingo 07773 421479
