Well I must be the odd one out here, Im running about 13.95:1 CR, Street driven in fact driven EVERYWHERE, ! do run it on 99ron, and have run it on 97, but I have never had any problems with, I however run a lot of cam overlap, the 14:1 as stated is static comp, but im guessing the dynamic comp is around 11:1 cylinder pressures are about 260lbs so from memory thats around 11s, The cam I use is a European touring car cam, [Tom Wilkenshaw] ETCC which is limited on its lift to 0.330" at cam which I think is the same as the Rover Twin Plenums, but the cam timimg is pretty wild, but it does work,
