1 - 11 of 11 Posts
V8 addict
A friend of mine has a set of what he refers to as "cosmic alloys" on his BGT.
They are 14 inch rim, 5.5J wide and have a PCD of 114.5 mm
I'd like a set for myself. However, I am having real trouble finding them in any size let alone the correct size. Am I searching for something by the wrong name?
Are they indeed "Cosmic alloys" or are they something else completely?
Here's a picture:
Thanks in advance,
JC.
Yep, I reckon they're Cosmic slots. I had a set a little while ago complete with the centre caps. I'm not sure anyone else made them with those conical centres?
Banjo snapper.
I'm pretty sure they're Mk4 Cosmics.
I can see why you are after a set they look just right on the BGT but wolfrace also look very good on the MG :tup:
V8 addict
Discussion Starter · #6 ·
Thanks everyone. It's nice to know I'm not looking in the wrong direction. They are so rare, though!
Viking, I've already got a set of wolfies on the car. I'm trying to go for a sort of pro street look, with some deep dish slotmags on the back and a pair of the cosmics on the front. :tup:
JC, if you're after those in particular you may well not find them advertised as Cosmics, just as simply "slot mags" or similar. But if you've got wider Wolfrace on the back then why not hunt for some matching narrower ones?
V8 addict
Discussion Starter · #10 ·
Cheers chaps.
If only Argos still did them. My problem would be solved, then!
1 - 11 of 11 Posts
