1 - 17 of 17 Posts
Desparado
Crate engines look great for the money, compared with a full rebuild of your old one.
Are they all there cracked up to be ? Theres load of tales of getting them here & there nothing but trouble, but is it just hearsay ?
Any feedback, good or bad ?
Sheep Shagger
I was going to go the crate motor route, but after my mate said he would rebuild it free of charge as he wanted to do one before rebuilding his own I went down that route.
For my money I bought a Stroker kit and had the motor lightened and balanced, etc as it was only a few hundred quid more than a stock rebuild, so I guess it depends on what you want the engine to perform like too.
If I had to do it myself I'd have bought a crate motor as I wouldn't have the 1st clue how to rebuild an engine.
I'm sure a few people will be along in a mo with crate motor recomendations.
I guess it depends what you are wanting to do ? I havnt heard any bad stories about crate engines. Pound for pound they are the cheapest way to get a new motor.
If I needed a new motor for our ,56 I would buy a crate motor....:smoke:
yer i had my sbc race motor built in the states.bill todd built it,ive got to say they can screw an engine together.so far touch wood all i have had to do on the motor is change the oil and plugs .and the engine has done everything i asked for . you can see your face in the blower,its 1200bhp and its been reliable:tup:
crate motor
i run a 4 bolt main crate lump with edelbrock goodies on it touch wood it been ok and anyone who knows me knows i give it more abuse than a politicians expense account,value for money you cant beat them,cut out engines are all together different,........that my penny worth..
Talking strictly street engines here: the basic old style Goodwrench crate motors as sold by Real Steel are great! 2 guys I know have these in their rides and are both happy with value and performance one kept his as standard and one upgraded his after about 2 years with an edelbrock rpm pack[ heads cam air gap intake and better dizzy] Both cars perform well and the rpm one is awesome! I have a home rebuilt 350 sbc in my Firebird properly checked and machined by a reputable company and while I am happy with the result I would admit that I saved a few hundred £ but the Goodwrench is all new top to bottom... remember good machine shops are not cheap and cheap machine shops are not good. Short cuts and used parts=trouble down the line.
Ive been running a Goodwrench 350 for 10 years in the Bigjob.thats 3 tons empty,an half its life its around 5tons, and then a caravan for good measure,if it blew up tomorrow,id phone Real Steel up and order another without batting an eyelid,Bry
I've used a few crate SBC's over the last couple of years.
They were the most cost effective way of sorting out worn engines.
What with the dollar as it is and the rise in the cost of shipping, I'm not so sure how they stack up at the moment.
Always take the sump off and check the bottom end out. I've had one very loose oil pickup pipe and one that was laying in the sump!
I have a crate zz4 in the A..no probs at all...to build a SBC to that spec without the poss machining works out pretty close to buying a crate motor. mine has 340-350bhp at the flywheel and 280 at the wheels (off the dyno)
Got salt
I got lucky & won a HO-350 deluxe back in '01. Stuck it in the elky where its performed flawlessly ever since.
The HO is probably a better deal than the ZZ4 if you dont need the ally heads. Although theres 20HP difference on paper, the difference is said (by Hot Rod) to be much less on the dyno.
Again, in Hot Rod a month or 2 back, they showed you'd be almost 100HP better off just getting a ZZ4 short block and decking it out with edelbrock heads etc, for about the same money as a complete ZZ4.
Member/ Reject.
For me it would be a rebuild, i've done 2 now with my dad and half of one alone, makes it more fun.:D
It may be fun matt but like others have allready said it works out more expensive ? And if you dont have all the equipment to measure all the tolerances your enginge might not last as long as one that is factory built> I would go down the crate route myself
Never had a problem with the 2 crate motors i've bought.
If it worries you though, buty thru someone like WASP or other UK suppliers. The engine still comes from the States but the UK supplier issues the guarentee.
Dragging not Bragging
Id guess it depends on funds and what you want from an engine
If i had the money, Id buy a crate (with an engine in) :pmsl:
But
As you know im re-building (stock) my chevy and at the moment its cost less than an empty crate :tup:
1 - 17 of 17 Posts
