FIRST OFF
I'm not saying this is the only or best way of doing it ,just what worked for me.Secondly,I'm crap with a camera,crap with a computer and so,please bear with me!
STUFF REQUIRED
Drill press,engineers square,permanent marker,steel rule,wire brush approx 7/8 inch dia,jubilee clip,leccy tape,lubricant(machinists type,Rocal etc),item to be engine turned and lots of patience and a steady hand!
STEP 1
I first marked out a sheet of stainless with a grid of 1/2 inch squares using the marker pen ,square and rule.(see pic)
STEP 2
Bind the wire brush with leccy tape and firmly secure a jubilee clip arround it about 1/4 inch from end to stop it splaying out too much
STEP 3
Set drill speed at about 500 rpm.Generously lube the work piece and,from top left corner,using the grid as a guide,lower the brush into contact with the stainless.Apply gentle pressure in an up and down motion for about 10 secs but do not allow the brush to loose contact with the work piece.Take note of the reading on the drills depth gauge to ensure a consistent pattern. Once you've done the first "swirl",lift the brush from the work piece and move to the right and make a second,overlapping the first by 1/2.Carry on until the first row is completed.
STEP 4
Start the second row as above,over lapping the first row by 1/2.Then continue until work piece is completed.
TIPS
The above is just a guide,practice on scraps until you get your technique right.Do the job in stages,that way you can spot mistakes and correct them as you go,rather than have to start from scratch.If you're tired/pissed off,take a break,it's dead easy to screw up.Every now and then,clean the work piece and re-mark the grid if necessary.I used the lubricant undiluted as when diluted it goes everywhere and removes the grid lines.
The attached photos should help. Good luck,it will do your head in!
STUFF REQUIRED
STEP 1
STEP 2
STEP 3
STEP 4
TIPS
