Does anyone have any advice on the removal of the the door hinge pins on an F1 stepside, I am fitting new swan neck mirrors and they fit through the top hinge bolt, The old pins are a swine to remove, I have added some heat and the weight of a hammer but no joy!!!
Andy
Moved to correct section for you, Bry
carefully drill the bottom of it out, there are splines on the bottom which are about 8mm long and its these which dig into the hinge and hold it in place. once you get rid of those it should hammer out.
