If it helps anyone... The system is a 3" bore, each bank a separate system (no cross over, balance etc) and is bassically a 3" stainless pipe from the header with a kick-up over the trans mounts into a resonator box (steel) and then a thrush muffler (ooer missus). exhausts in front of the rear axle.
Was fitted to my 57 bel air but as it is basically two straight pieces of pipe / mufflers it would adapt quite easily..
has a good tone and volume
In Essex.
In Essex.
