I only have one fan, I'm wondering what one I should get like if it comes on at 190 and shuts of at 170 for example??if you have a twin set up I have a diagram which runs both and varies the speed to temp
sounds about right.I only have one fan, I'm wondering what one I should get like if it comes on at 190 and shuts of at 170 for example??
Regards Stuart
Sent from my LYA-L09 using Tapatalk
Yeah it's a stock 350sbcCan you confirm what engine you are using again?
If its a SBC then fan cutting in at about 200 and shutting off at around 190 is about right. Shutting off at 170 is too cold and probably wont ever shut off as you wont get the temps that low. Engines need to be a minimum of 180/185 to evaporate off the water vapour in the oil.
This is the kit I was thinking of???Can you confirm what engine you are using again?
Perfect thanks for the helpThat should work fine (though you could to your local Allparts or Euro Car parts and order a switch for about £10 and a relay for about a fiver?)
You might need to play with the temp sensor to get it right which is why I went back to my adjustable Kenlowe controller in the end as I just could not get the right temp sender range to suit my car (which was a bit tricky to be fair).
Your truck should be easier as its a much bigger engine bay so should behave better to the controller.
There's nothing like spending £100+ on something from the states when a £20 fix from Euros will work, probably better. :tup:That should work fine (though you could to your local Allparts or Euro Car parts and order a switch for about £10 and a relay for about a fiver?)
Very trueThere's nothing like spending £100+ on something from the states when a £20 fix from Euros will work, probably better. :tup:
Perfect cheersGoing by that wiring diagram ONLY then the grey/white is the power in for the relay SWITCH circuit.
This is used for EITHER the ign + to control it or the switch to control it.
This ONLY controls whether the fan can run when the ign is on - OR - if using the switch when the switch is on.
If you want to use the switch as a manual override switch then you would add it into the black wire to the sender and then via the switch to ground. This would trigger the fan as if the sender was saying it was too hot. The switch would not illuminate if wired in this way though.
Personally I would not bother with the illuminated switch (use a non illuminated one) but I would add it into the black wire circuit as the override. Run the grey/white to an ignition controlled circuit so fan goes off when ign off.
If you refer back to my wiring diagranm I posted you can see how I wired it - if you want a bigger version PM me your email addy as I can't post bigger images here.
