1 - 6 of 6 Posts
hiya guys i,m after a bit of advice,i,m fitting a 2.0 litre twin cam sierra engine in my moggy.i have the loom and ecu but does anyone know if i need anything else(the engine is comlete with coil paks)thanks in advance
Heavy Oiler
Not sure but you may need the Ign key and receiver around the ignition barrel for the imobiliser to work.
MAP sensor ( small black plastic thin box ) with vacuum feed and potentiometer ( small black thing with a screw adjustement )
1 - 6 of 6 Posts
