This is a 25 litre petrol tank fitted with a sender and a pick up. It is very thick, well made fibreglass in grey gel coat.
It is a used tank and was fitted under the floor of the car hanging from the thick flange around the centre. It doesn't leak but someone has made a half arsed repair to the filler neck with Plastic Padding - but you're rodders and can sort that out......
It is 37" long, 7" deep (not including the neck) and 17" at the widest point. Would fit well between a set of pop chassis rails or similar.
For collection (from Chester) or you pay postage. I want £50 for it.
These are a pair of Pop Browns exhaust cones in mild steel that have been chopped about for a Pontiac and have had three primary pipes welded in.
Some surface rust but they have never been used. They have block off plates and I will include the 90 degree bends to connect up to the exhaust systems.
For pick up or you pay postage. I want £30 for them.
