i need your help.i am in process off painting bonnet which didnt look to bad.i flatted it back and put a coat of primmer on it when i noticed loads of tiny cracks in it.so i sanded it right down and painted it againand they still come thruogh.is there a cieller i can use to fill cracks.thanks danny
A couple of coats of filler primer should cure it. You could even roll it.
Buy it from any auto paint stockist.
Jeff
Woodchipper Extraordinair
Upol reface polyester spray filler, comes in 1 litre tins, you'll need a gun with atleast a 2mm tip to spray it with but it should sort it out, block it back with 180 or 240 depending on prefernce then prime as per usual.
As a foot note dont try to thin it and when you come to clean your gun use acetone as it has some sort of weird reaction with thinners.
fixin your car
and it is like a sponge so dont get it wet
