Im a oldie
Hi guys got a 350 sb starts first turn of the key every mornig runs strong not a miss but when I have gone a distance the bloody thing wont start im running elec egnition some canadian built small dissy edelbroke carb 650 electric pump .lve been told module breaking down fuel evaporation regulator not putting out 12v anybody else had this problem because buy the time I get to check things its cooled and starts.
I've had a similar problem wth my '64 Galaxie, 390 w/Holley & Edelbrock manifold. Starts fine from cold but after a run & leaving it for a short time it won't start until properly cooled down. I've looked on a few Ford forums & the general consensus seems to be fuel evaporation due to the stuff they put into modern gas which makes it more prone to vapourise. I've not properly addressed this issue yet, but last time I looked at the motor when hot the see thru' fuel filter looked to be dry, it was resting against the block so I moved it away to allow a bit more air flow. The forum posts did suggest an auxiliary electric fuel pump mounted near the tank to push cool gas through, which now worries me as you say your car has already got one!
I'd go with coil as well, check your petrol line isn't too close to anthing that could cause vapourisation as well.
Does your battery crank fine when the car is warmed up. I say this because I had the same hot start problem and it turned out to be the battery plates.
check your coil to start with
mmm! car porn
If your still running points it could be the condenser breaking down when it gets hot, that or coil as suggested.
